Re: Farmall 100 with very loose seed plate drive ??
Posted by Ramon in Krakow on August 13, 2013 at 09:23:27 from (173.38.209.8):
In Reply to: Re: Farmall 100 with very loose seed plate drive ?? posted by mkirsch on August 12, 2013 at 05:24:01:
Hi Folks
So I only had a few minutes to work on the
tractor but I took a quick video which seems to
show something interesting.
http://youtu.be/kSlkRqfve3c
I was moving the seed gear around and when I tried
to pull it out a little, I saw that it was
actually attached to something which I believe is
the oil seal (which was sliding out---in the video
it is the bright and shiny cylinder). I could not
see the bearings at all. Am I reading things
right? If the oil seal is falling out but at
least still in place, then hopefully not too much
trash would have been getting in the bearings,
which would be a relief.
@mkirsch
Thanks for the info on the final drive. I
checked the manual and it said that those level
plugs were both the level and the fill plug.
Should I just open the plug and try to fill it
until it starts to seep back out? Given that it
has been leaking, I am sure it is probably short a
good quantity of oil.
