Re: Farmall 140 hydraulics
Posted by Erik Dekeyser on August 13, 2013 at 09:52:29 from (184.151.61.109):
In Reply to: Farmall 140 hydraulics posted by Spanky54 on August 13, 2013 at 05:30:36:
Well if the fluid is up to where it should be than maybe you should check the filter its below where you check the oil just remove the 4 cap screws and pull out the filter. If that looks good than you might have to check the pump or you might have to rebuild the hydrolic box.
