Re: Farmall 100 with very loose seed plate drive ??
Posted by mkirsch on August 13, 2013 at 10:08:32 from (64.80.110.75):
In Reply to: Farmall 100 with very loose seed plate drive ?? posted by Ramon in Krakow on August 09, 2013 at 03:10:59:
The oil seal is completely missing.
See those four empty holes around where the shaft comes out? That is where the seal retainer bolts on.
No seal retainer, no seal.
The shiny cylinder is the surface that the seal rides on.
You can see the inner axle bearing quite clearly. That is the circle around the shiny cylinder. Luckily it is shielded so there isn't much gunk getting in there.
There is no doubt about it. You need the seal and seal retainer.
