Re: Farmall A Magneto
Posted by pete 23 on August 13, 2013 at 10:46:41 from (74.47.41.165):
In Reply to: Farmall A Magneto posted by cubluvn8n on August 13, 2013 at 04:41:55:
Where are you checking for spark. Make sure you check directly from the coil wire by pulling wire out of cap. That way you will determine if you have a problem in the rotor and cap area or coil, points condenser area. Points must be perfectly clean set to .013 and a common problem when guys replace points is they do it on the tractor where they cannot see things clearly. Get a dab of grease on points or not align them properly or allow the wire to touch side of mag frame. If all that checks out , most likely coil.
