Re: Thanks for the advice
Posted by truckerlary on August 13, 2013 at 18:43:52 from (12.19.152.194):
In Reply to: Re: Thanks for the advice posted by Lmack on August 13, 2013 at 18:35:04:
I haven't tore into the original engine as of yet but what I'm seeing is the front crank pulley is moving up and down about 1/8 of an inch or so when you pull on the fan belt. I'm thinking it's going to need some serious machining. Larry
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
