Re: Fixing 1945 Farmall B Brakes
Posted by gene bender on August 14, 2013 at 06:18:57 from (207.177.56.41):
In Reply to: Fixing 1945 Farmall B Brakes posted by Wayne Rimathe on August 14, 2013 at 06:11:56:
If you do one side at a time no problem. I use a cherry picker to remove the final drives. Left side can be removed easy remove the diff housing along with final drive. Drivers side if you want to replace inner seal will be more of a problem as drivers platform needs to be removed also.
