Re: Re: Re: This Dist. Has Steped On My Last Nerve
Posted by Bob M on November 28, 2000 at 17:24:42 from (172.133.57.121):
In Reply to: Re: Re: This Dist. Has Steped On My Last Nerve posted by Merlin on November 28, 2000 at 16:39:03:
Merlin - The advice the others have provided - especially about the condenser - is right on. When you get the new condenser installed however, try this test: Take a good plug wire and stick a good spark plug on one end. Lay the spark plug on someplace grounded. Take the other end of the plug wire and plug it in the coil output nipple. Finally, turn on the ignition and manually open the points with a screwdriver. If you get a fat spark at the spark plug each time you open the points, your ignition system is fine as far as the distributor. (If not, there's a problem with the coil/points/condenser...) Once you verify your getting fire outta the coil, next step is to retime the distibutor. Paul Schuler's our expert on that! Good luck! Bob M PS - I encountered the same "no spark" problem once. Cause turned out to be corrosion under the condenser can was not letting the condenser ground properly to the distributor breaker plate. Spent an entire evening trying to figure it out!
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
