Since this is an IH forum I'm going to assume that you are asking about the differences between the TA (partial powershift) and the forward and reverse (shuttle) option.
The TA uses a planetary gear set to give a slower speed option when the clutch holding it in direct drive is released. The tractor continues to move in the same direction.
The forward and reverse option also uses a planetary gear set but uses a shift collar to select either forward or reverse direction of travel.
There are differences in both the TA and F/R option depending on the tractor model but the principle remains the same.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
