Posted by Owen Aaland on August 14, 2013 at 14:15:32 from (216.47.34.48):
In Reply to: Starter Noise posted by Melvin Ware on July 22, 2013 at 06:55:40:
What you are describing may be caused by the drive not retracting on the helix splines.
The M starter used a drive that is engaged by inertia. When the started is energized the rapid acceleration of the armature causes the drive to extend forward on the helix splines. It remains forward and engaged with the ring gear teeth until the engine starts. Once the engine is running it spins the drive faster than the armature is spinning which causes the drive to retract back down the helix. The little spring is there to keep the drive from going forward when the starter is not is use.
You should be able to spin the drive in and out on the splines with little effort. If not the drive may stay engaged with the ring gear.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
