Re: Farmall 460 Wiring Issues...
Posted by Owen Aaland on August 14, 2013 at 19:09:51 from (216.47.34.48):
In Reply to: Farmall 460 Wiring Issues... posted by Absent Minded Farmer on August 14, 2013 at 18:31:06:
It sounds like you have lost an electrical connection some place. Here is a source for the wiring diagrams.
460 wiring diagrams
You will need to follow the diagram for the small wire from the battery stud on the starter up through the ignition switch and down to the coil.
It actually should have run while cranking if the problem is in the switch but check all the wiring first and make sure you have spark at cranking. If you have spark we can look at other possible causes.
