Odd that it leaks out there, figured it would run down the torgue tube to the hole at the bottom of the bell housing, but maybe being gear oil it cools and just doesn"t travel that far. If you split it of course I change the throw out and pilot bearings, check over your clutch disc and pressure plate real well. the one place to play particular attention to is the bolts/nuts at the joint of the drive shaft...we had a couple loosen up and eventually back out, had to replace the whle joint! Good luck!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
