Sounds like the front seal on the transmission input shaft. First off, is the transmission overfull? Check for water at the drain plug. If contaminated, flush it and refill but don't fill above the level plug.
If after that you still have a leak, replace the input shaft seal. To do that you need to split it between the bell housing and the transmission. Only split it as far as you need to access the u-joint in the input shaft. Take that joint apart to get to the rest of the disassembly. Do not pull the front part of the shaft out of the bell housing any more than required to get at the joint. If you pull it too far, it will drop out of the throwout bearing carrier. Good luck if you do that.
Accessing clutch parts requires a split between the bell housing and the engine. You should not need to do that as part of this job.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
