Re: 10-20 HP
Posted by robgIN on August 15, 2013 at 14:40:58 from (76.208.6.203):
In Reply to: 10-20 HP posted by HenryV11 on August 15, 2013 at 06:10:07:
An F-30 head is different, the intake and exhaust valves are different size and stems are bigger than 10-20. The difference in manifold and carb also make a difference. If you swap enough parts you could probably make similar HP. The gearing is the biggest thing working against you in the old F series and W series and 10-20, 15-30, they are geared a little fast and that makes pulling that extra bottom a bit difficult.
