Re: @ rex simpkins identify 2 row fh planter
Posted by couv on August 15, 2013 at 19:23:40 from (24.32.175.2):
In Reply to: @ rex simpkins identify 2 row fh planter posted by couv on August 13, 2013 at 20:04:45:
One difference between my unit and a 251 I could see on the CASEIH Parts website --
The 251 FH points "bend" to where they are narrower on the end that attaches to the tool bar.
On my unit, the FH points are straight from tip to toolbar.
Another thing that may not show well in the pictures, behind the toolbar pointing directly backwards is a tube. The depth Adjustment wheel and Turn Wheel attach to the rear-most point of this tube. At the front of the tube, there is an about 18 inch steel bar, left-to-right. At each end of the bar is a hole. In each hole is a J-hook bolt about 2 ft long pointing upward. A large spring is around each J bolt, with a lock nut. Looks like maybe this is an adjustment point that lets the entire planter unit swivel like an airplane wig-wagging its wings (can't think of any other way to describe the movement)
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
