Re: year of my farmall H
Posted by D Slater on August 16, 2013 at 09:24:12 from (184.14.161.237):
In Reply to: Re: year of my farmall H posted by august smarra on August 15, 2013 at 19:16:28:
If that's the engine serial number posted and the K you mention is a date code and on most or all other parts its had a engine change sometime in its life. If that is the case you are out of luck on knowing what the original serial number was. If the engine was original the engine and chassis number would be the same.
