Posted by Janicholson on August 16, 2013 at 10:28:53 from (74.60.94.18):
In Reply to: 450 oil pressure posted by Steve43 on August 16, 2013 at 08:30:25:
Cold with 30wt, 0r 15-40, they are always above 60psi idle to wide open. Hot they can be as low as 35psi Idle and above 60psi open. (the gauge was usually pegged high when working) When worn for a long time, they will be OK with 15 psi idle warm, and 40 psi at high RPM. Low pressure is one or a combination of: Worn end plate and gears in the pump Loose cam bearings Loose rods/mains Check the oil pump first. Jim
Today's Featured Article - Tractor Profile: Earthmaster - by Staff. This tractor, manufactured by the Earthmaster Farm Equipment company in Burbank, California was made for only two years. The Model C came out in 1948 and was followed by the "CN" (narrow-width model), "CNH (narrow-width high-crop model), "CH" (high-crop), "D" and the "DH" (high-crop) in 1949. The main difference between the models was tire size, tractor width and cultivating height. The "D" series were about 20 inches wider overall than the
... [Read Article]
Latest Ad:
[More Ads]
