Re: Will PTO from Farmall 200 fit a Farmall Super A??
Posted by RTR on August 16, 2013 at 11:53:21 from (216.226.179.180):
In Reply to: Will PTO from Farmall 200 fit a Farmall Super A?? posted by RTR on August 16, 2013 at 08:31:08:
Yeah, I'm not sure as I have never done it. Maybe someone on here has done it before or knows something so you want have to be trying out stuff and swapping parts unless you know it will work.
