Re: Will PTO from Farmall 200 fit a Farmall Super A??
Posted by Gerry Powell on August 16, 2013 at 15:47:18 from (173.172.82.103):
In Reply to: Will PTO from Farmall 200 fit a Farmall Super A?? posted by red farmer 84 on August 16, 2013 at 08:28:34:
The housing will work but not the gear. On the SA the gear has 44 teeth and the 200 (the same as the C) gear has 48 teeth. I recently replaced the bearings in my pto and cracked the housing trying to get the gear off the shaft to get at the bearing. These gears are hard to remove, to get the gear off the C, I had to split it with a torch and use a lot of heat, and it was still a bear.
