Re: 1928 Little Genius 2 bottom plow
Posted by Tom Fleming on August 17, 2013 at 03:01:52 from (67.20.233.75):
In Reply to: 1928 Little Genius 2 bottom plow posted by Tom Fleming on August 16, 2013 at 03:23:56:
Thanks everyone for the replies. This is in overall pretty good condition, except for where the wheels were sitting for years in the dirt. Which is why I have the replacement set of wheels for it.
My plan is to restore this over the winter, and use it at plow days. I'll start the dis-assembly soon, and figure out what parts I'll need to replace, hence the question on the bolts.
The bottoms are 14" and this was pulled behind the Regular here is Pa. Looking forward to see how the old girl does after I clean her up and make everything right. Probably too much for the F-12, but the Regular and the F-20 should do just fine.
