Re: alternator conversion farmall m
Posted by FBH44 on August 17, 2013 at 03:57:24 from (64.85.216.37):
In Reply to: alternator conversion farmall m posted by butch49 on August 16, 2013 at 20:32:13:
Here"s some notes I made 20+ years ago going from 6V generator to 12V alternator in my "H". These are just things to be aware of, to check out. Not saying htis is complete. I got all this advice from NAPA where I bought the alternator. There"s a man names CharlieU who sells the diode, and has a great wiring diagram along iwth it. Hopefully he"ll give you better advice, but here"s mine;
12 Volt GM Alternator with internal regulator
$10 resistor IRC23
Reverse the coil wires
Reverse the battery
Reverse the wires on the amp gage
Therefore everything will be negative ground
Wire from the Start button to the new resistor to the coil
Leave the old voltage regulator
• Run Battery terminal to ‘BA’ terminal on alternator
• Remove ‘GEN’ wire and scrap it.
• Remove ‘F’ wire and scrap it.
