Re: Farmall M not wanting to start sometimes
Posted by El Toro on August 17, 2013 at 06:20:47 from (108.3.143.3):
In Reply to: Farmall M not wanting to start sometimes posted by mikes54jubilee on August 17, 2013 at 06:10:09:
Your battery voltage may be dropping too low for your distributor. When you pull start it you're not using your starter and your battery voltage doesn't drop. In regard to the white smoke are you losing any coolant? Hal
