A weak battery (just a little weak will do it) or high resistance cables (corroded at terminals or internally) poor ground or hot connections a starter switch that is getting hot when used, are all possible causes (maybe some of the baove together) cables on a 6v M should be 00gauge. Smaller wires will not roll it over with enough voltage left in the ignition to fire it. To see if this is the case, jump the coil with another 6v battery (supplying Negative to the coil and ground from the jumping ignition battery)with the ignition switch off, and roll the starter. if it starts, you know it is low voltage at the coil. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
