Re: 684 clutch
Posted by JimB2 on August 17, 2013 at 18:14:36 from (96.30.165.123):
In Reply to: 684 clutch posted by peter82 on August 17, 2013 at 12:07:40:
Hi Peter, did you mark the old clutch disk as to which side was facing the flywheel and which side faced the pressure plate and installed the new clutch disk in the same way. IIRC the side of the clutch disk with the springs exposed the most faces the pressure plate. I don't recall there being any adjustment on the pressure plate fingers. The only adjustment was on the clutch pedal rod.
Did you install the clutch disk and pressure plate on the transmission and PTO shafts and then connect the transmission part back to the engine and then attach pressure plate to flywheel through clutch inspection hole? If not there is a possibility of bending clutch disk paddles.
Maybe someone else can add some additional help.
JimB
