Re: W9 clutch stuck
Posted by Bob M on November 29, 2000 at 07:20:41 from (192.232.120.194):
In Reply to: W9 clutch stuck posted by Tom H on November 28, 2000 at 14:44:53:
The clutch facing has rusted to the flywheel/pressure plate - not unusual for a tractor that's been sitting a while.
I've had good luck doing this: Stick the tractor in 5th gear, then with the clutch disengaged pull it alternately a few feet forward and then backward. Repeat until the clutch breaks free. Unless it's stuck really bad, the torque reversals will bust it loose after a few cycles of the above.
Don't put any more Liquid Wrench etc. on it however - otherwise it's likely to slip once it's broken free.
Post A Followup
: Re: Re: W9 clutch stuck
