Posted by D Slater on August 18, 2013 at 04:12:55 from (184.14.161.237):
In Reply to: Re: 350 Distributor Help posted by Oregon Tractor Jack on August 17, 2013 at 20:22:29:
That's the spring set for a O symbol distributor and a LP distributor. Engine speed needs to be 400 RPM or lower to use a timing light for TDC or 0 advance. Should have about 8 degrees advance at 800 RPM.
Depending on if its a utility or a row crop IH changed springs a few times from start to end of 300 and 350 production gasoline tractors. Set you have is about all you can get for them the last I checked and there is not a hole lot of difference in the advance rates.
This post was edited by D Slater at 04:25:35 08/18/13.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
