Re: How Do I Remove the Crank Pulley on a Super A
Posted by CNKS on August 18, 2013 at 08:22:54 from (216.144.104.128):
In Reply to: How Do I Remove the Crank Pulley on a Super A posted by RTR on August 17, 2013 at 19:36:37:
My 1953 Super A has the place for a crank and a nut. I replaced mine by putting an adjustable splitter behind the pulley to keep it from breaking and a 2 jaw puller. It is very tight and will make you think you broke something when it breaks loose. I did not use heat to replace it, just the nut that holds it on. There was no set screw, on mine anyway.
