Re: How Do I Remove the Crank Pulley on a Super A
Posted by rtr on August 18, 2013 at 08:54:27 from (98.83.137.165):
In Reply to: Re: How Do I Remove the Crank Pulley on a Super A posted by greg k on August 17, 2013 at 19:48:19:
I would like to see some pictures if that is possible because I didn"t see a place for a nut at all. It just has the crank "ears". Wouldn"t I need to put a bolt in the middle of the pulley for the jaw puller to push against? Where would I find a bearing seperator?
