Re: 560 steering and hydraulic fluid fill
Posted by DeltaRed on August 18, 2013 at 10:33:45 from (97.118.31.225):
In Reply to: 560 steering and hydraulic fluid fill posted by Unstylish on August 18, 2013 at 09:32:21:
look to the right of the gearshift.There is a little triangular shaped plate.That is the fillport.On the leftside below the clutch pedal is the level checkplug.Its ok to add 2-3 extra gallon(up to 5) of fluid after it starts to run out.You should order a book.These guys(YT) have them.
