Posted by RPM1941 on August 18, 2013 at 11:43:57 from (173.19.112.127):
In Reply to: 560 HYD line leak posted by Unstylish on August 18, 2013 at 11:18:56:
This the main high pressure line to the valve stack, part CNH 370964R91, the bottom is a 3 bolt special manifold sealed with oring, the upper a 1-1/16 ORB thread sealed by oring, the leak usually comes from the swivel joint next to threaded nut, there is a fibre or nylon ring that seals the swivel joint not sold by CNH or even listed. The price is high for hose assembly. Get a used hose, 560 only, 460 not same, or take to a good hyd shop & see what they can do.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
