Posted by Tom Fleming on August 18, 2013 at 17:16:34 from (67.20.233.75):
In Reply to: Gear Oil in a M posted by F-Dean on August 17, 2013 at 19:08:06:
Well, all the previous answers are fine, but I will add a little detail. Is this a show tractor or are you gonna work it? Show tractor, 80W90 is fine, and is also what I run.
If you are going to work the old girl, next question I have is what is the climate where you are at, and when do you plan to use it the most? Warm climate, hard work (plowing, disking, etc), I would go with the heavier lube.
If you live in MN, WI, SD, ND or similar, and plan to work her in the winter, like snow plowing, I would probably go 80W90 as well. If you live in a warmer climate, go heavier. All the older manuals I have seen offer pretty much what I just told you, except they say to add a little Kerosene in the winter, and then change it out in the spring. Gear lube is too expensive today to operate like that. Plus, today's gear lube has a much longer life.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
