Re: Farmall 300 Generator Replacement
Posted by gene bender on August 19, 2013 at 07:44:59 from (207.177.56.41):
In Reply to: Farmall 300 Generator Replacement posted by zlarryd on August 19, 2013 at 06:12:07:
F on the gen to F on the reg A on the gen to gen on the reg and batt volts to the Batt on the reg from the amp guage. Polarize the gen touching Batt term to the A term momentary getting a spark. Then with engine running check amp guage. A terminal on the gen should read 7 or so volts. If it doesent charge ground the field that should show charge but does show reg is bad if grounding the A term doesent show voltage gen is bad and take it to a shop.
