Re: Farmall 460 wiring
Posted by farmallboy15 on August 19, 2013 at 08:38:00 from (172.243.36.179):
In Reply to: Farmall 460 wiring posted by tjoeerry on August 19, 2013 at 08:10:39:
Does the stationary part of the points have continuity to the ground? The points provide the ground to the coil so it can fire. With the ignition on the points should spark when you open and close them with a screw driver. If you are getting spark across the points it is a cap and rotor problem. Do a search for John T's trouble shooting guide it is very complete and will get you there!
