Re: ih 1256 wats it worth
Posted by ejr-IA. on August 19, 2013 at 09:38:13 from (204.11.182.17):
In Reply to: ih 1256 wats it worth posted by tony lochard on August 16, 2013 at 18:31:07:
Go buy you a 400 series motor from combine or tractor and the few extra parts, many have been done this way.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
