Re: Farmall 460 wiring
Posted by Janicholson on August 19, 2013 at 10:16:31 from (199.17.6.25):
In Reply to: Farmall 460 wiring posted by tjoeerry on August 19, 2013 at 08:10:39:
THe issue is likely to be grounded lead to the movable point. Often at the pass through on the side of the distributor. I will bet that the point side of the coil shows no voltage when a piece of plastic is put between the points and the key is turned on. If so the point spring and conductor, the condenser lead, or the small bolt is touching ground at the distributor case of point mounting plate. Jim
