Posted by RPM1941 on August 20, 2013 at 09:25:03 from (173.19.112.127):
In Reply to: 1206-Pop and Backfire? posted by Toby Harter on August 19, 2013 at 21:07:31:
Don't know what exactly is wrong but this engine was problematic in that the front crank pulley (the dampener) the rubber fails & breaks off cam gear tooth, in extreme failures it breaks camshaft right behind gear, crank gear teeth, bends pushrods, & pistons hit valves. The crank pulley has rubber molded dampener inside, it will deteriorate & crumble, you can see/feel at front edge. If yours checks out ok, good for you, but if it don't get a new one, 701036C93 IH part & expensive, they cause so much damage not good to try a questionable used pulley.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
