arkfisher said: (quoted from post at 19:21:48 08/19/13)
Before I swapped the carb out, I had it cranking by hand fairly easy. I had to pull it to get it started this time, and it sounds pretty good to me. The mag is good and hot, and the timing marks are spot on. What can I do to make it easy to crank again???
Put the working carb back on. you never said if you rebuilt the brass one or just cleaned it. Something is obviously not right with it or it would not change how the tractor starts. 12's can be very sensitive starters if something is off just a tweak. Also I don't see a new gasket between the carb and manifold, may be a air leak if you reused the old gasket, Should be a fairly thick one in there.
This post was edited by 36F30 at 19:31:24 08/20/13.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
