I just got done making a new pump drive setup on my 3414.
As to your's - it all depends on the serial number and which pump it has.
Early 3414 has a pump with a round shaft and single key.
Later 3414 has a 7/8" X 13 splined shaft just like many Deere, Fords, Cases, etc. use.
On mine - the pump had the 7/8" X 13 splined shaft. Then a 7/8" X 13 splined coupler that you can buy on this Website as a Ford part.
From that coupler - the shaft is 7/8" X 13 splined on one end - BUT tapers down and is only 3/4" splined on the other where it connnects to the drive plate on the crank-pulley.
If your coupler is bad, it's likely the shaft and drive-plate on the crank pulley is also bad. I adapted all new parts that I bought here. All for a Ford loader. New rubber-cushioned drive plate with a 7/8" X 13 hole instead of 3/4". New 7/8" splined shaft, new 7/8" splined coupler.
If ALL you want is a coupler - you can buy here under Ford. 7/8" X 13 internal splines.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
