Re: FEL Hydraulics worse than ever
Posted by mkirsch on August 21, 2013 at 08:01:48 from (64.80.110.75):
In Reply to: FEL Hydraulics worse than ever posted by Paul57 on August 21, 2013 at 02:26:59:
Two way = pressure up AND pressure down.
Typical loaders around the time of the SH were ONE-way. Pressure up, gravity down.
The upper ends of the large cylinders were often used as hydraulic reservoirs, with the oil just flowing freely back and forth into the hydraulic tank on the SH.
If you've got a period-correct loader, and high pressure on the "retract" side of the cylinder, you likely have one of two issues:
1. Piston seals blown.
2. Hoses hooked up wrong.
