Most likely you have single action cylinders. They come basically 3 different ways.. 1. cylinder rod is full size of the bore , so no oil or dead air space above the piston seal...2. rod is somewhat smaller than the bore and there is a breather on the top end and air flows in and out as the cylinder is cycled and 3. as mkirsch indicated, there is no pressure, but that space is used to hold fluid so the reservoir level does not vary so much, in which case there should be a low pressure hose attached to the upper (rod) end.
Long cylinders are notorious for holding air and it takes a while to get it all worked out. One reason is when retracted to ground level, the cylinder is usually not retracted all the way. run the front wheels of the tractor up on something so the cylinders retract all the way and see if that helps.
BTW, the cup things are the pressure seals, the things he gave you are the parts that center it in the bore and prevent metal to metal contact, piston to barrel.
This post was edited by IH fan at 09:02:39 08/21/13.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
