Re: turning plow hook-up
Posted by Haas on November 29, 2000 at 14:18:15 from (129.37.117.55):
In Reply to: turning plow hook-up posted by Ricky on November 29, 2000 at 10:10:47:
The drawbar turns around and bolts to the front drawbar bolt holes, not the normal holes where the drawbar is attached when facing rear. You control the plow depth by adjusting the drawbar up and down. Also to get started, the drawbar has to be in a low position, so the plow point will dig in. There is supposed to be a control rod that attaches to the touch control to adjust the drawbar, but those usually are gone. I did had one and did in manually. Once you get it set it will work. There are also some eccentric bolts in the hitch that ajust the side to side tilt of the plow, which need to set so the plow share is level when at plowing depth and the wheel in the furrow. The lift chain attaches directly to the rockshaft arm that is on the fenders. I never saw one that had a separate bar to attach it between the rockshaft arms. The one I once had was a two way plow and had a special rockshaft arm that could drop only one side at a time. Each of the two plows attached to the rockshaft arm on the side the plow was on.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
