Posted by MarkinOhio on August 22, 2013 at 05:29:39 from (206.211.222.52):
In Reply to: mor cub help please posted by ericlb on August 22, 2013 at 04:33:23:
I'm assuming when you say that you're getting"fire at the coil" you're refering to the high voltage lug on the coil itself and that you do have high voltage there. The coil cover has a flat metal spring that must make contact with that lug when it is installed. From there of course it goes by way of the high voltage coil wire to the center of the distributor cap and then to the 4 spark plug wires in the proper order. I can't tell from your post what you mean when you say that nothing is comming out of the cap. The coil cover cap with just one high voltage wire or the actual distributor cap with the coil wire and 4 spark plug wires? If you're actually getting high voltage at the coil but nothing comming out of the coil cover cap make sure the spring is making contact with the coil lug. If you're getting high voltage out of the coil cover but not to the distributor cap I would change the high voltage coil wire. If you're getting high voltage to the center terminal of the distributor cap but nothing out to the spark plugs check that the carbon rod in the center of the distributor cap is making contact with the distributor rotor and that the rotor is good. Distributor cap not cracked? All 4 terminals good? Spark plug wires made of solid wire and in good shape?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
