Re: Farmall 450 Coil Voltage
Posted by D Slater on August 22, 2013 at 05:47:21 from (184.14.206.221):
In Reply to: Farmall 450 Coil Voltage posted by LMJ on August 22, 2013 at 03:19:27:
Gasoline serial 11084 and higher came 12 volts with resistor and also used a different magnetic switch on the starter and a extra wire in the harness to bypass the resistor when starting. IH did sell complete kits to change 300 to 450 tractors that came 6 volt over to 12. 12 volt LP used a resistor serial number 11093 and higher. 12 volt diesels used a resistor 13491 and higher. LP and diesel below the above serial numbers were originally 12 volt and no resistor.
That's how they came but lots of things are changed after 50 plus years.
This post was edited by D Slater at 10:49:45 08/22/13.
