Posted by Pete in Holland MI on August 22, 2013 at 07:30:53 from (198.36.94.35):
In Reply to: zeinith carb F20 posted by jmix on August 22, 2013 at 06:17:43:
If you set the float to the specs, and it doesn't leak, you should be OK.
I think his reference on the bowl plug is to verify that after it emptys, that there is still a strong flow of gas to the carb. A weak flow would indicate blockage in the tube or at the base of the gas tank. Crap in the tank can impeed flow of gas to the carb. Impeeded flow would most likely result in a tractor that will start, but begin to fail a few minutes into running, and/or under a load.
After cranking and it doesn't start, are your plugs dry or wet? If dry, you are not getting gas. If wet, something's a-muck with your spark.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par
... [Read Article]
Latest Ad:
[More Ads]
