Re: Farmall 450 Coil Voltage
Posted by John T on August 22, 2013 at 12:15:44 from (216.249.76.176):
In Reply to: Re: Farmall 450 Coil Voltage posted by LMJ on August 22, 2013 at 05:56:26:
Nope, if its a 12 volt coil you want to feed it 12 volts NOT 6 WELL DUHHHHHHHHH if you use a voltage dropping (12 to 6) ballast resistor ahead of the coil, then you only leave 6 volts for a coil designed for 12. It still can spark albeit weak.
John T
