Re: Farmall A Woods Belly Mower
Posted by Owen Aaland on August 22, 2013 at 17:18:58 from (216.47.35.45):
In Reply to: Farmall A Woods Belly Mower posted by crookedwrench on August 20, 2013 at 18:01:35:
If the back of the deck is lower than the front the grass is cut about twice as much. The front of the blade cuts the grass off the stem and then as the mower goes forward the back of the blade is lower so it continues to cut a little more off all the time until the grass stem passes out the back of the mower deck. If the front of the blade is lower the grass will not be cut any more once it passes by the spindle.
