Re: zeinith carb F20
Posted by Ron W on August 22, 2013 at 17:28:43 from (24.247.83.82):
In Reply to: zeinith carb F20 posted by jmix on August 22, 2013 at 06:17:43:
You said you just finished restoring it. Did you
paint it? If so, then the mag might not be
grounded well and thus weak or no spark even
thought the mag is hot. You can use a continuity
tester to make sure the mag is grounded.
What I do is wire brush out one of the tapped
holes in the mag and make sure it is corrosion
free, wire bush and shine up the threads and
inside of the head/lock washer of the bolt, then
scrape off the paint where the head/lock washer
contacts the mag bracket. I coat with dielectric
grease and tighten down. Always works.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
