Re: 656 d not starting
Posted by John A. on August 22, 2013 at 17:53:16 from (64.128.16.238):
In Reply to: 656 d not starting posted by ihjason on August 22, 2013 at 17:23:52:
Jason, Another YTer here on the Forum told me this trick to get a IH Dsl to start.......
1.. get hood off!
2.. remove rubber hose between Air-cleaner and Intake
3.. get a 1qt oil squirt can w/ trigger pump, mix 50/50 gasoline and Dsl. Shoot and goodly amt into the intake (a large portion will go into #3 & #4 cylinders, will some lesser into #2 & #4 cylinders, and lesser yet in #1 & #6. Add a good dose of ether (only if you Glow plug system is suspect!!!! Do not use Glow plugs at all!! )
4 do step 3 while turning the engine over it should start in a little while.
I did this with a D282 IH Dsl and res-erected , a presumed dead 706 from the dead!
Hope this helps!
Later,
John A.
I had broke prime by putting new Filters on and such!
