The 450 diesels did use 3 different coil setups. One was 12 volt coil, one was 6 volt coil with external resistor and then they dropped the resistor and still used a 6 volt coil. Put more new coils on those diesels than all the gasoline tractors combined. They went to the straight shaft with no advance and made a hard starting tractor even harder so they left off the resistor and used the 6 volt coil alone. Going through that cut off switch on the manifold they didn't use a bypass wire coming from starter solenoid to go around the resistor for starting. That is the way I remember it anyway.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
