The clutch on an F20 is not adjusted by Free Play. This is not a letter series tractor. The petal should be firmly held to the transmission stop by the return spring attached to the rod. Then you open the inspection cover and adjust the clearance between the throwout bearing and the clutch with the throwout bearing pushed back in contact with the fork. The adjustments are done with the rod and the clearance, not free play. This should also compensate for the extension someone welded on to make the clutch easier to push. All the necessary dimensions for your clutch are in this chart. Specifically dimension C.
This post was edited by 36F30 at 19:11:44 08/22/13 2 times.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
