Posted by Dieseltech on August 22, 2013 at 19:11:11 from (199.16.223.2):
In Reply to: 656 d not starting posted by ihjason on August 22, 2013 at 17:23:52:
Just loostening the line nuts at the injector is not enough, best to tap the line and make sure the line sleeve pops loose. The SV7922 line sleeves wedge in tight each time the line nut is drawn down. I like to remove all glow plugs to allow engine to crank easier. When fuel is at each injector, then tighten the line nuts. Crank again until you see air/fuel mist at each glow plug port, install plugs and start engine after heating plugs. If you never get fuel you may have metering valve and/or stuck plungers. Or worse, a seized head/rotor assembly.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
